Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-30-2007, 01:44 PM
ned032002's Avatar
ned032002 ned032002 is offline
What do you guys think?
A guy i know is selling his 1st gen Eclipse GSX, lots of mods heres the list he gave me
NEW RADIATOR
16G TURBO
2G EXHAUST MANIFOLD ALL PORTED TO 7CM
OIL FILTER RELOCATOR
OIL COOLER 7 QUART SYSTEM
2.5 RRE EXHAUST HIGH FLOW CAT
GR2 KYB STRUTS
EIBACH SPORT SPRINGS. NEW HALF SHAFTS
WHEEL BEARINGS
ACT 2600 CLUTCH
REBUILT TRANSMISSION BY TEAM RIP
NEW TIMINGBELT
BALANCE SHAFTS REMOVED
NEW WATER PUMP
DEJON INTAKE
PVC CAN
STRUT BAR
SOLID URATHANE ENGINE MOUNTS
URATHANE DRIVE SHAFT MOUNTS
JENSON MP3 PLAYER
TWO 12 KICKER SUBS
AMP
CAMPACITOR
SHIFTER BUSHINGS STEEL
BLITZ TURBO TIMER
17 WHEELS
NEW WANLI TIRES
INGALLS UPPER REAR CONTROAL ARMS
NEW REAR HALF SHAFTS
AEM FRONT ROTOR CONVERTION.
$3000
Heres a little bit of info on the car
"IT IS A 5 SPEED. SHE IS ALL WHEEL DRIVE. I BROKE ONE OF THE REAR HAFT SHAFTS BECAUSE I WAS RACING AND I DID A 6000 HOLE SHOT AND THE CAR SNAPPED IT LIKE A TWIG. SHE IS RUNNING STOCK BOOST. ABOUT 15. SHE HAS A LOT OF ROOM TO GO FAASTER. I HAVE KEEP A CLOSE EYE ON THE TRANSFER CASE. I HAVE HAD IT OFF MANY TIMES AND EACH TIME I TAKE THE INSPECTION PLATE OFF AND TAKE A LOOK SEE. I HAVE REPLACED THE SEAL IN THE END BECAUSE THAT IS WHY TO GO. SO SHE IS FINE. THE CAR HAS ABOUT 129000 ON IT. IT STILL PUT ABOUT 180 COMPRESSION ON ALL CYLINDERS. IT ALSO HAS A NEW 02 SENSER KNOCK SENSOR. CLUTCH MASTER CYLINDER, AND SLAVE CYLINDER. AND A BRAIDED STEEL CLUTCH LINE. ONCE AGAIN THERE IS MORE."
Well?
Old 05-30-2007, 01:47 PM
steviek's Avatar
steviek steviek is offline
Re: What do you guys think?
2200
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 10-24-2007, 08:36 AM
ned032002's Avatar
Alright so I am buying this car here soon. It is a '91 Mitsu. Eclipse GSX AWD w/ 130k and a 5 speed fully built tranny. I am already looking into what I would like to do next and I am considering a Walbro Fuel 255 Fuel pump and then rewireing it. But since I am still just in the learning stage to becoming a Jedi, I need some guidance. This car will never be used as a daily driver, garage kept for the most part. I want to do everything right the first time and I want everything to be sound w/ the car.
http://www.extremepsi.com/store/cust...cat=560&page=1
I found out that shes running about 15psi and the car has a crushed BOV. Now I was looking into the Greedy RS BOV but those are mad expensive for something that I have that already works.
What should be the next mods I should be looking at? I was looking into possibly a FMIC but I am not at all familiar w/ how they are installed or what they are capable of or what specs you need to have one but like I said any guidance is better than none at all. Thanks guys.
Old 10-24-2007, 09:41 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Sounds like your friend is full of shit. Stock boost on a 1g is 10 psi and to the best of my knowledge the stock compression is 160... theres no way I can think of it would be turning out 180 psi like that. Not to mention its obviously been raced a bunch. I dont know Ned, I would pass if I were you. Also, what the hell is a "6000 hole shot"?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-24-2007, 10:05 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
I'm guessing he dumped the clutch at 6k and broke something. With my recent compression tests I did some reading up on them. I've read that if alot of carbon is built up on the piston then that will boost the compression giving a false reading. Or maybe he did a wet compression test and boosted the numbers up. Either way though with a car thats been abused like that and has 130k, and hasn't had a rebuild or anything I call bullshit on the flawless compression numbers.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-24-2007, 10:20 AM
ned032002's Avatar
The car really hasn't been raced, it has been tested to the limit I guess but I'm looking for a project car not a daily driver. I expect to do a rebuild some time in the future any way so I'm not really worried about it. This guy has taken care of this car I truly feel that it hasn't been abused a whole lot, I know dropping the clutch at 6 grand isn't taking care of the car but I'm sure everyone here has done some dumb things just like this so I'm not worried about it. Besides he's a good friend of mine and I've watched him w/ this car and he really takes care of things. He has checked the transfer case religiously for leaks as well as changing the timing belt.
So I am buying this car and just never mind how you feel if you would or wouldn't buy this car but what would you do with modding with what I've got?
Old 10-24-2007, 10:21 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Ya he already said stuff broke due to him racing. Unless you're pulling the motor, I think that's a bad idea. Race cars are bad to buy 2nd hand.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-24-2007, 10:34 AM
ned032002's Avatar
I'm not like attempting to defend him but by him saying the work racing could have easily meant accelerating fast, attempting to get to point A to B faster, such as if I were to say "I raced to KFC before they closed cause I really could go for some potato Wedges". So he could have meant anything by that.
And perhaps you guys are right but I have a good feeling about this car.
Old 10-24-2007, 10:51 AM
Dropping the clutch at 6k most likely means he was doing some kind of street/track racing. There's no way people just do it for the hell of it while driving to the store or whatever. Unless he was practicing his launch, doing it for no reason is just stupid. If you already plan on doing a rebuild and fixing the problems then go ahead and get it. As long as you think it's worth it, then thats all that really matters.
94 Talon 1.8L-SOLD
Old 10-24-2007, 11:17 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
don't do it ned, sounds beat to shit. you will end up with a 10,000 dsm that is worth $1,000.
Old 10-24-2007, 11:57 AM
david-b's Avatar
Dave is THAT guy
Nice story and could be, but look at what he says
Originally Posted by Some guy selling car because he raced it a lot and now it's too broken for him to fix it without dropping fat cash
Doesn't sound anywhere close to "racing" to KFC.
75 Monte Carlo
Old 10-24-2007, 12:05 PM
ned032002's Avatar
It's obvious that nobody wants to help me modifiy this car so I'm not even going to bother. It's worth it to me so I'm doing it. Mod lock this thread.
Old 10-24-2007, 12:07 PM
EDMUND65's Avatar
when you need any parts, such as engine, transmission or transfer case.... www.car-part.com works great...
Old 10-24-2007, 12:10 PM
david-b's Avatar
Dave is THAT guy
You asked what we thought. And we're telling you what we think. If it's worth it to you then do it. But you asked us, the general public. You know we'll always help you modify it, but maintenance and keeping it running is important also. Which is why we pointed out the little things that makes us believe that this may not be the best purchase... but again, that's out opinions and we're entitled to them.
Originally Posted by EDMUND56
When you need any parts, such as engine, transmission or transfer case.... www.car-part.com works great...
And honestly, this just sounds like an ad.
75 Monte Carlo
Old 10-24-2007, 12:35 PM
EDMUND65's Avatar
ok dave. i do a lot of work on people's cars in syracuse. mostly piece of junk cars where you cant get parts from the dealer or parts stores. You have to search junk yards. I only have three around me and its nice to know they have a parts locator. just putting it out there.... fine lock it idc
Closed Thread
