Old 05-30-2007, 12:09 PM
HondaSi88 HondaSi88 is offline
I need a 96-00 3.3 Transmission
Mine is really starting to go........it throws all kind of transmission codes and the thing will downshift whenever it wants.
Anyone know someone or know of a place that sells the 3.3 transmission?
email me or call i need this soon
thanks
[email protected] or 240 498 5394 kevin
Old 06-01-2007, 08:56 PM
Rawtorque Rawtorque is offline
Re: I need a 96-00 3.3 Transmission
What kinds of codes? This could be just a wiring problem, the TCM needing update, or a clogged filter.
Old 06-02-2007, 09:14 PM
i pulled about 10 codes......from the speed sensor to the gas light going up and down.
Its just crazy!!!! i'll post them when i find where i put them
thanks
Old 06-03-2007, 01:36 PM
I wonder if you have an electrical problem with so many codes coming up. This is essential for this transmission to operate right.
Old 06-08-2007, 11:54 PM
I have TONS of problems........man i think it might be time to just tow this thing to the dealer and get something new...
where is the Alternator fuse?
Old 06-09-2007, 12:33 PM
mcmalloy mcmalloy is offline
You should check the ground stap on the tranny , if it is broke all kinds of stuff happens . I heard of pepole replacing the tranny when its only the ground stap thats broke.
jsinton jsinton is offline
Try looking on EBay for a trans. They run about $800 delivered, brand new rebuild.
Old 06-09-2007, 05:02 PM
wafrederick wafrederick is offline
Banned
Get one from Jasper and they do updates on that transmission.They weld the end of the spider gear pins,Chrysler does have problems with them breaking and does damage to the case.They also have a better warranty,you can take it to any Jasper dealer for warranty work if there are any problems.The other places,you have to take a certain place for warranty work and the warranty sucks.The worst part is that unnessary back mount thanks to a really dumb Chrysler engineer that needs to be shot.
Old 06-10-2007, 09:37 AM
EZFrank EZFrank is offline
check the wiring connectors maybe loose or corroded and yes sometimes ground strpsbreak off and could cause problems.
[IMG]http://[/IMG]
