Old 05-30-2007, 10:55 AM
Arrowshooter Arrowshooter is offline
98 Power Windows
On the way to work today I put the driver side window down and it will not go back up . Do the switches wear out on these things before the motor goes? I know it is not a fuse because the passenger side works. Thanks.
Old 09-24-2007, 03:57 PM
20sonthe98 20sonthe98 is offline
Re: 98 Power Windows
hey the same thing happend to my truck. it turned out to be a loose wire. just take the panel off, test the switch w/ a ohm meter, and if it proves to work wiggle the wires on the motor and that should solve the issue.
Old 09-25-2007, 08:55 AM
Frankp87 Frankp87 is offline
I had the same thing happen on my 98 Silverado. The switches checked out ok as well as the connections. I pulled the motor and found it to have a "dead" spot in the windings. I was told this happens with use. Nothing to do but replace the motor. I found mine at Rockauto.
Frank
Old 09-26-2007, 12:21 AM
Just so happens, while I was taking it apart I decided it give it the "old starter" trick and tapped it with a hammer. Well low and behold it has been working ever since.
Old 09-26-2007, 07:22 AM
Arrow, hopefully that worked but don't be surprised if it stops working again. I had the same situation. Seems the motor would stop on a good part of the winding for a while but then hits the dead spot again. I kept putting it off util the window stopped working during a rainstorm and yes, it happened to be down.
Frank
