Go Back   Automotive Forums Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 05-30-2007, 09:25 AM
HoustonHelix HoustonHelix is offline
Cylinder Misfire - after new plugs/wires
The scanner indicates "#6 CYLINDER MISFIRE".
I replaced the sparkplug and sparkplug wires on that cylinder and checked the contacts in the distributor cap. Yet, I continue to get the same message.
I would greatly appreciate any advice or theories. Clogged injector?
Thanks!
Old 05-30-2007, 05:04 PM
flyinMKIV's Avatar
flyinMKIV flyinMKIV is offline
AF - Advisor
Send a message via AIM to flyinMKIV
Re: Cylinder Misfire - after new plugs/wires
I know that in the MKIV's #6 seems to have the most trouble with this, try cleaning the plugs and trying again. The reason it is is because it's where most of the oil buildup occurs in the cam compartments and sometime due to a bad seal it can leak into the spark plug cannal and flow down to number 6 causing a misfire. Again, check and make sure that the plugs are clean as well as the cylinders when you put them back in. Also check and make sure that there is no oil or anything else in the spark plug canal and if there is replace the gasket.
Another thing could just be timing, check and make sure everything is in time, it can be a pain but goes a long way. Hope this helps.
02 Honda Accord (Sold)
93.5 Supra non-turbo (Sold)
94 Lexus GS300: 2jzgte swapped (sold)
08 Scion TC (daily driver)
94 Supra Single Turbo (Sold)
97 Top Secret Widebody Supra Turbo (Work in progress)
If your talking trash, I'll be showing my ass
http://www.automotiveforums.com/vbul...d.php?t=535850
http://www.automotiveforums.com/vbul...d.php?t=212356
Old 05-30-2007, 10:36 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Do you have spark?
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
