Old 05-30-2007, 01:07 AM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Transmission Down! Need Help!
Okay, i have a 92 K1500 with the 5.7L and an automatic transmission. (i assume 4L60). I have no Reverse and VERY LITTLE forward gear at all. I can get it to go a little if i put it in gear(not Drive though). Any ideas what this might be?
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 05-30-2007, 10:13 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Transmission Down! Need Help!
Have you checked the fluid level and transmission filter?
MT
Old 06-06-2007, 10:17 PM
dawnnewsome3 dawnnewsome3 is offline
It is a 700r4 4l60 trans took one from a 92 GMC K1500 and put it in a 88 Chevy C1500 my trans was doing the same thing the clutchs was bad in mine reverse and 4th use same clutches and planetery gears if I aint misstaken . you should try filter first they can cause low pressure problem that can cause this symptom also , good luck.
Old 06-07-2007, 05:31 PM
abaird abaird is offline
If it has fluid then it is probably time for a rebuild. Probably the foward clutch. 4th gear uses a 2-4 band to engage on the 4l60 which isn't a real high failure point unless you tow in overdrive.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
