Old 05-30-2007, 01:04 AM
HoustonHelix HoustonHelix is offline
CYLINDER MISFIRE - Experts help, please!
The scanner indicates "#6 CYLINDER MISFIRE".
I replaced the sparkplug and sparkplug wires on that cylinder and checked the contacts in the distributor cap. Yet, I continue to get the same message.
I would greatly appreciate any advice or theories. Clogged injector?
Thanks!
RON
V6 MitsuDiamante
Old 05-30-2007, 09:11 AM
534BC 534BC is offline
Re: CYLINDER MISFIRE - Experts help, please!
if it has decent compression and the timing cannot be wrong then yes the mixture is probably lean due to lack of fuel or air leak.
Old 05-30-2007, 09:17 AM
UncleBob UncleBob is offline
AF -Advisor
do you feel the engine misfiring? Is it idling rough, or chugging when moving?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-30-2007, 09:28 AM
There is very minor chugging when at idles, but the Engine Service Light remains on. Scanner indicates there is still a misfire on the same cylinder I replaced the plugs and wires on.
Old 05-31-2007, 05:51 PM
INF3RN0666 INF3RN0666 is offline
hey man, i have the same issue on cylinder 2. I would check the resistance of the injector first and see if it's electrically fried. If it's not, it could be clogged, which would be you would have to swap the injector of with another cylinder's injector. Then reset the codes and see if the misfire changes cylinders. If the misfire changes cylinders, then you have a bad injector. If it doesn't, then you're screwed just like me.
