Old 05-29-2007, 10:54 PM
turbo_b00st's Avatar
turbo_b00st turbo_b00st is offline
styrene tubing size
hi,
im wondering what size of styrene size tubing if i wanted to make an exhaust.
I know the size needed for making the muffler from the faq and how to's.
Also what is the average size styrene needed for scratch building majority of the other aftermarkets items? ex : disk brakes,etc.
thx!
mike
Old 05-30-2007, 12:33 AM
Enzoenvy1's Avatar
Re: styrene tubing size
Well, if you are looking to do exhaust, I would recommend using 3mm solder or the like. There are countless sizes of Styrene tubing so the choice is out there. I would go to your LHS and see what is best. I use the solder for the 1/24th that I make.
As for the other question, again, there are countless sizes of Styrene out there. I just picked up a pack at my LHS that is a odds and ends pack. It is loaded with a ton of sizes of tubing, sheet, etc...
I would say try your LHS. I found the 3mm solder at Home Depot.
Old 05-30-2007, 12:39 AM
Ooo...very good idea for the exhaust with the solder and i will check out the local hobbylobby.
thx!
Old 05-31-2007, 03:42 PM
Another question: what kind of styrene is used to make an intercoolers?
I went to towerhobbies website, and noticed there were some v-grooved, clapboard, and a few others. i wasnt sure which ones to order; can someone help? lol
thx
Old 06-01-2007, 11:36 AM
Enzoenvy1's Avatar
thx
I cannot think of anything that would be easy other than making your own. Search this forum for the how to's. If not there, links should take you to one.
Old 06-01-2007, 02:16 PM
ok,
im thinkin just using an xacto blade and ruler to make the lines.
thx
Old 06-06-2007, 10:51 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Try Ace Hardware for solder. I picked up a tube of 1/16 Kester solder for less than $2.
Also try aluminum tubing for exhaust parts, much more realistic than plastic, but a little trickier to form.
Bob
