Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-29-2007, 09:22 PM
mpfilms mpfilms is offline
Any body know about this code?
P0430 mod 10 1/1
Catalyst Efficiency
Below Threshold
Bank 2
Does anybody know what could be causing this code and what I should check?
Thanks
Old 05-30-2007, 06:35 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Any body know about this code?
Your code is for the drivers side converter not operating properly. As far as telling you how to fix it, the test for the P0430 or P0420 is about 75 steps long and time consuming. If everything else is in good working order, (tune up, no vacuum leaks, no exhaust leake, fuel pressure good, all sensors in the correct parameters) then the converter is at fault. It is not a definate fix without doing the complete test.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-30-2007, 08:16 PM
Now if I do take care of this right away, will other codes pop up or will all chaos happen.
Thanks
Old 06-03-2007, 06:51 PM
way2old's Avatar
TOKEN HILLBILLY
Sorry for delay in answer. I would erase the codes and see how long it takes for it to return. Sometimes it may not return for a long time, and other times it comes back quickly. If it returns quickly, there is a definate problem causing the code. If it takes a long time to come back, it could have been something as simple as a tank of bad fuel.
