Old 05-29-2007, 08:40 PM
lurch1 lurch1 is offline
97 Z24 cav help please
I turned the key over today and nothing happened but all the power works. So I took out the starter had it tested witch was bad so I replaced it and still the same problem. I bypassed the key ignition by putting jumper cables and a toggle switch to the starter. It started once but after that it cranks over but doesn’t fire up. If can help me I would appreciate it.
Old 05-30-2007, 04:40 PM
cta2885 cta2885 is offline
Re: 97 Z24 cav help please
well, if it cranks but doesnt fire, it could be a few things. Listen to see if your fuel pump is turning on. if it is, then have someone crank the car and see if your getting fuel to the injector. if you are, the next step would be to check for spark. those are the first two things i would check. let us know what you find out.
Old 05-30-2007, 07:50 PM
it only cranks if i use the jumper cables to the starter .if i dont use that and try with the key nothing happens it doesnt even crank but the power comes on
Old 05-30-2007, 11:58 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Having 14'ish volts is different from generating the amperage needed to start a car. Your battery is probably dead, go to an autozone or an advance auto, they test batteries for free.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
