Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-29-2007, 11:32 AM
vcrafty vcrafty is offline
foggy headlight lens on 97 mercury marquis
My headlight lens are foggy on the inside. They seem to have moisture build up and a residue. I've cleaned the outside but don't know how to remove the lens to clean the inside. I've been told that I need to replace the lens. They are about $200 dollars each so I'm looking for an alternative. Any suggestions?
vcrafty
Old 05-30-2007, 09:31 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Re: foggy headlight lens on 97 mercury marquis
It is very common for these to "fog" on the outside. Are you sure it is on the inside? If it is there is not much you can do as these are sealed units. Check the outside by putting some automotive polish on it and buffing it out. It fixed my 1998.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 06-06-2007, 06:10 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
My '97 has that too, but totally on the outside. I bought one of those Permatex kits, which was about $10 and a waste. You can do the same job with some light compound and a rotary buffer. Another idea, check at a glass shop for anything they make to restore weathered plexiglass, boat places should have it too.
Bob
Old 06-07-2007, 10:43 AM
baron1701 baron1701 is offline
Polishing Compound Worked Wonders For Me, I Had My Doubts Untill I Started Rubbing The Fog Off.
Old 06-07-2007, 03:15 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If it is on the inside, the lenses are held onto the bucket by silicone. You can take them aart and clean them. However, you need to be really careful when trying to separate them or put them back together. If the silicone you isn't a really high quality, the lens will fall off the bucket and you will have more troubles.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
