Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 05-29-2007, 09:12 AM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Exclamation 99 Expedition Problem
I have a 99 expedition that when I step on the Accer. it starts to shutter like it missing horsepower
opcorn:
Old 05-29-2007, 08:50 PM
bearcat329 bearcat329 is offline
Wink Re: 99 Expedition Problem
is there a check engine light on? have the code read, could be either a vacuum leak, or a bad coil
hth
Rick, Ore
Old 05-29-2007, 09:07 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
If there is no check engine light, then hook a fuel pressure guage to the fuel rail and see what it reads when acting up.
Old 06-28-2007, 12:40 PM
boxiedoxie boxiedoxie is offline
Here are some possibilities: ignition system not operating properly, Dirty or clogged fuel injectors, fuel pump, or filter, engine control system malfunction, incorrect ignition timing, faulty or incorrectly gapped spark plugs, dirty air filter, faulty ignition coils, incorrect transmission fluid level, EGR system not functioning, low or uneven cyclinder compression pressure, or vacuum leak at intake manifold or hoses. I'm not going to go through how to check each one, but I will tell you that your local parts store should have a repair manual for your vehicle. I like Haynes: Ford Pick-ups & Expedition 1997 thru 2003. It has great troubleshooting pages and very informative. Hope this helps.
