Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 05-29-2007, 05:57 AM
taylanemilyme taylanemilyme is offline
Water/coolant Temp Sensor
Any of you all ever had problems with the water temp sensor ( or it may be caled the coolant temp sensor)??? I think I have one that acting up an a 90 model B2600I.
Thanks
Old 06-05-2007, 01:07 AM
mikecee48 mikecee48 is offline
Re: Water/coolant Temp Sensor
Sticking thermostats could do the same thing. A worn out fan clutch could cause it to get hot while idling.
Old 06-05-2007, 06:44 AM
Well I never thought about the thermostat. It's not running hot but it does not want to start on a cool morning. If it gets warm and the sensor is plugged in, it may start to run a little rough and it will blow a little smoke when you hit the peadal and you can smell fuel. I assume it's running "rich" when this happens. Just looking for options. The other weird thing is that the coolant temp sensor that the auto parts store shows for the truck dies not match what is in the truck now but the plug on the wiring harness would not fit anyway. So I dont know what this mean. The one that matches in the computer is for a 93 model I beleive.
Thanks for any info.
Eric
