Old 10-24-2002, 09:46 PM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
times
Can someone please post up times on a stock mustang gt (94-99)
thank you
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Old 10-24-2002, 10:00 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
The best times I have seen for a 94-98 gt, is a 14.9 at the local dragstrip on a 1996 GT. Bone stock, original paper airfilter and air silencer. Now I have not personaly seen a 99 or newer mustang GT run, but car and driver rates it at about a 14.2 on a 5-speed.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 11-06-2002, 02:28 AM
qtr_mile_freak qtr_mile_freak is offline
i raced 4 differant 99& up mustangs this summer...the fastest was a 2001 w/ cold air ind., h pipe, flowmaster, and short shifter...it ran a 14.5. when a magizine advertises a time it is usualy about 2 to 4 tenths faster that what you can run. i dont know if its because they have pro drivers or what. i have a 2002 acura rsx type s. they advertised my car to run a 14.7 stock. i could only get it to run a 15.2...i dont know why they do that. it pissed me off when i ran that as my fastest time! but anyway i think that a stock 99up will run about a 15.5 or so...because i can beat one... (these times could also be slower than expected because summer in mississippi is kindof muggy and hot...)
Old 12-07-2002, 06:53 PM
C32Bperformance C32Bperformance is offline
My guess would be mid to low 15s, since thats what my Si does, and i seem to run very even with them.
Beauty is in the eye of the beer holder.
Old 12-08-2002, 06:00 PM
94svt5.0's Avatar
Here in ky, high 14s to low 15s is the norm. It all depends on driver.
1994 Cobra
-off road h-pipe
- stock
-K&N
Old 12-19-2002, 09:52 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
A good driver should be able to net high 14's, depending if the car can hook up and track conditions.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-22-2002, 02:55 PM
Los Los is offline
Send a message via AIM to Los Send a message via MSN to Los
96-98 I've heard as low as 14.9.
99-02 I've read 13.7 but I've only seen from a stock car, 14.2s.
all with 5speeds.
Los
Texas Racing Scene.com
Lawton Racing
Old 12-23-2002, 01:48 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
With slight mods, I have seen a 99 Cobra run 11.85. That's Bob Cosby's car, of course.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 12-23-2002, 02:33 PM
Los Los is offline
what kind of slight mods!?
Los
Lawton Racing
Old 12-23-2002, 03:07 PM
SkylineUSA's Avatar
Air Filters, pullies, gears, solid rear axles, ECU tweeks, and exhaust. Nothing major.
Old 03-16-2003, 02:28 PM
BigCheech BigCheech is offline
Had a 98 GT with ported heads cold air intake and 3 inch exhaust, no mufflers only cats..best time i could run was a 15.2
Old 03-16-2003, 04:07 PM
HiFlow5 0's Avatar
Stanger
Pretty bad times! I think if you had addressed that exhaust system you would have net better times! There's no need for 3" exhaust unless you pushing more then 400hp. And only running cats, I bet you were losing some torque.
-2013 Ford Flex
-1999 Ford F150
Old 03-16-2003, 06:14 PM
the engine in the GT pretty much took a crap so i said forget and purchased the cobra
