Old 05-29-2007, 02:29 AM
dale_40422 dale_40422 is offline
Unhappy 2004 Ranger Fuel Pump Issues...AGAIN!!!!!
Is it possible to replce the in tank factory fuel pump with an in-line pump on the 2004 Ford Ranger 3.0L? I'm certain the issue isn't the enertia switch. These in-tank pumps won't hold up & I'm tired of replacing them...It's too expensive for another 10,000 miles & then do it all over again. This was NOT one of Ford's better ideas!
Old 05-29-2007, 09:33 PM
INF3RN0666 INF3RN0666 is offline
Re: 2004 Ranger Fuel Pump Issues...AGAIN!!!!!
They have warranty man. fuel pumps are expensive but they're also warrantied for a year. I don't know if you'll even find an inline pump for the ranger. People don't just wake up one day and say "i'm gonna reinvent the ford ranger's fuel pump with an inline one". I'm sure you can mod an inline pump to make it fit your car though. I dont know how much luck or experience you'll have with that.
Old 05-30-2007, 09:07 AM
UncleBob UncleBob is offline
AF -Advisor
if its a single line system then an inline definitely wouldnt work. The regulators in the tank (or its voltage limited).
Really, wouldn't work anyway. you'd have to take apart the fuel pump assembly and modify it to work with the inline setup. Not impossible (if its a 2 line system) but a bit of work
As for the pump failures, are these stock pumps that are failing, or aftermarket pumps?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-08-2007, 12:58 AM
waycool9's Avatar
waycool9 waycool9 is offline
Technician/ Designer
Have you tried a fuel pump relay, if it has one?
