Old 05-29-2007, 12:26 AM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Not a Chevy question, but...
I can't get a response from the Mazda guys so I thought I would give this a shot.
My daughters 2000 Millenia with a supercharged 2.3 engine recently overheated. I changed the thermostat and refilled the cooling system and now it won't start. The engine will crank over but won't start. Someone told me to pull the fan relay #2 and use a jumper to get it to start but with the jumper in, the car then won't turn off. Does anyony have any ideas? Could it possibly be the coolant temp sensor? If so, where is it located?
Links to pics of relay with and without jumper
http://i177.photobucket.com/albums/w...a/HPIM0632.jpg
http://i177.photobucket.com/albums/w...a/HPIM0630.jpg
Thanks for any help,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 05-29-2007, 12:30 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Not a Chevy question, but...
is the relay burnt out or damaged?
Seatbelts Saved My Life
Old 05-29-2007, 12:54 AM
rob67gmc's Avatar
Damn, that was a fast reply!!!
Nope. Relay is fine. Swapped it with one from a friends car. Mine worked in his car but his wouldn't work in my car.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 05-29-2007, 07:08 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
damn, could that be an electrical problem then?? if yours works in his, and his dont work in yours rule of thumb, your not getting any juice....and by the way, i had no clue that car ever had a supercharger in it...was that a factory option?
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 05-29-2007, 11:33 AM
if your relay worked in his car, and i'm assuming his worked in his own car, then that points towards a problem with your relay box.
the relay itself isn't an issue, but check all the connections in the box, check that none of the wires are damaged or anything. sounds like maybe you've burnt out a circuit or some wire.
have you checked all the fuses?
Old 05-29-2007, 05:09 PM
philly rs's Avatar
see thats what im thinking...
Old 05-29-2007, 05:53 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Any codes in the computer? Sounds like something quit working properly and is causing the system to get confused.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 05-29-2007, 11:59 PM
rob67gmc's Avatar
Well, just got in from work, it's almost 1:00am, and after reading all your ideas, I ran back out and checked the fuses. Never even thought about a fuse. Replaced a blown 15 amp fuse and it fired right up. Amazing how something so simple made me look so stupid. Thanks for all the help!
Philly, I think the regular Millenia had a 2.5 and the Millenia S had the 2.3 supercharged. It doesn't seem to have a lot of take-off, won't even spin the tires, but at about 40mph or so you can nail it and it will throw you back in the seat. I would love to try one of these engines in a Miata or an older RX-7
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 05-30-2007, 04:27 PM
philly rs's Avatar
damn i never heard of a millinum s...thats a new one for me.. sounds sweet...throw that sum bitch in a rx-7 lol that would be a fun ride!!
