| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Oil disappearing
When i bought the car they said they had to replace an oil valve or cap or something but it fixed the leaking problem. Well even before my engine problem
i couldn't go without putting oil in between oil changes, my light would always come on. there is no oil spot in the parking spot, before my engine problem there was no smoke. any ideas? feedback would be great!
'99 Eclipse ( 10 year anniversary edition) ( non-turbo) And a toyota 4runner truck in progess. |
Re: Oil disappearing
Well if theres no oil spots then it sounds like ur burning it. My talon goes through about a quart a month, with no spots on the ground, and only at idle can u see a little blue smoke from the exhaust. With nearly 200,000 miles on it im sure the engine could use a rebuild, but it still runs fine and gets me where i need to go. I just make sure i check the oil twice as much as i do with my eclipse.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
Just how much oil are you losing? I know mine burns about a quart every 3k miles or so, and it dosn't really leak at all (no spots on driveway). It's pretty normal for a car to burn SOME oil, just how much is the question. I suggest you monitor your oil levels a little more closely, because if it takes the oil light for you to figure out that your low, your not checking it enough.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
well talon, that pretty much what happens, only recently it smokes pretty bad. But I mean before it didn't smoke at all, it the burning some oil bad?...and yes i'm new to cars...only recently have i found that i want to learn about cars..(mine mostly and trucks).
i had the oil light come on in my talon at the end of my oil change cycle prior to realizing i was burning it, i noticed my oil was very thin so i bumped it to a thicker oil and checked my oil here and there but never a oil light flickering again
1992 Eagle Talon TSi AWD
what kind of oil did you use that was thicker? and are you still burning oil? why did you burn it in the first place. sorry for so many questions...
