Old 05-28-2007, 09:44 PM
BrandonQ320 BrandonQ320 is offline
need help...methanol injection install
I just purchased a Coolingmist 150 PSI methanol water injection kit from a friend, and now I can't figure out where to put the spray nozzle. I have a 2002 GTP with the stock intake assembly. I was looking into mounting the nozzle in a throttle body spacer, but I could not find one. I would just knock a whole in the intake pipe, but I would have trouble sealing it off and i didn't want to mount it in front of the MAF. Anyone have any suggestions? Any advice would be very much appreciated.
Old 05-28-2007, 11:40 PM
frekey's Avatar
frekey frekey is offline
Re: need help...methanol injection install
http://www.zzperformance.com/grand_p...ts1.php?id=225
here you will find what you are lookin for at a fair price. good luck!
Old 05-29-2007, 05:11 PM
So, all I have to do is drill and tap a hole in the side of that throttle body spacer, and it will work just fine? Thanks for your help.
Old 05-30-2007, 09:35 AM
frekey's Avatar
should work. The same way you can add nos pretty much in some applications. Let us all know how the injection helps performance! good luck!
Old 05-30-2007, 09:23 PM
i've got a good one here. It's a plate made by thrasher for a NOS setup, but it should work for w/i too. Of course now I have to wait for the wife to allow me to buy it. She says we are broke. I say she is crazy.
http://www.thrashercharged.com/l67_htm/nos.shtm
now i'm having a debate about the bottle situation. I was thinking that i would take a windshield washer fluid bottle and put it in the fender on the other side so that i can use a bigger bottle that is more hidden. should i be able to put a factory washer fluid bottle in the other fender, or is there no way to swap it around?
Old 05-30-2007, 10:55 PM
OJ_ OJ_ is offline
I have done quite a bit of reading about water methanol kits. The general consensus from what I saw was that putting the injector before the supercharger is bad, and that it needs to go AFTER the s/c. It was said the the injection process can 'taint' the s/c and that it would cause problems given enough time.
I also would like to run this system, but I am a little miffed about having to drill/tap the lower intake(?) in order to 'properly' set up the system.
So can anyone here cast some light on how to use water meth safely?
BTW Frekey it seems that link leads to an un-listed item/page now?
2001 Silver GTP Coupe
Self-Tuned - HP Tuner, 1.9s, 105s, Coated Pacesetters(no cat), Poly MM, EGR del, ZZP 1.0 PCM, ZZP MPS 3.25-3.4, AL 104s, Wizair, TBS, 180 tstat, Falken 512s
Old 05-31-2007, 09:29 AM
frekey's Avatar
http://www.zzperformance.com/grand_p...=225&catid=113
strange how that changed but anyhow here it is again!
Old 06-02-2007, 12:27 PM
okay, this should be the last thing i need to figure out for the install. where do i plug my boost switch into. i was sure that i could just plug it into any of the vacuum lines, but now i'm not so sure. does anyone have any input on the matter?
Old 06-03-2007, 02:07 PM
never mind, i figured it out. i just ran a "T" off of the MAP and it is working fine. now all i have to do is wait until i order the throttle body spacer and i will be good to go. thanks for your help.
