Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 05-28-2007, 07:47 PM
ronald_durst ronald_durst is offline
1980 chevy c-10 bogs down during acceleration
I just recently got a 1980 c-10. i havent gotten it on the road yet but i have driven it around the yard. It seems like it bogs down when i gas it. It also doesnt have to much acceration. Anybody got any tips or anything on this truck.
Its got a straight six in it by the way. It used to be a standard but it was converted to automatic. Im not sure of its history. Jus wanna improve it the best i can. Thanks
Old 05-29-2007, 09:32 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 1980 chevy c-10 bogs down during acceleration
Try adjusting the idle mixture screws. Loostening makes it richer, tightening make it leaner. When you have a lean idle mixture it causes hesitation upon accelleration. Turn both idle screws out 1/4 turn. Drive it. If it hasn't changed do another 1/4 turn. If it still hasn't changed my then, it's something else.
Old 06-11-2007, 06:16 PM
4.3LjUnkBoXk10 4.3LjUnkBoXk10 is offline
check to see if your air filter is soaked in crap, gas oil, etc somthing, im only saying this because i used to have a straight six about 4 months ago lol, the throttle responce was horrible and seemd like it boged, air filter/ plugs / wires make a huge diff, and the reallity is, its a 25+ yr old pickup truck with a L6 not a 454 , the thing is a tank even if it doesn't bog, its not going to " move " its old and heavy not brand new. if you wanted somthing fast, should of looked into a monte w/ 454 lol good luck tho thats my negative 2 cents
Old 06-11-2007, 06:17 PM
Edit: and your "yard driving it" give it time to warm up as well. agian, good luck
Old 06-13-2007, 02:10 PM
heres another thought , i dont know what its called but, where the "throttle cable" connects to on the Carb.. / carb spring or w/e , try pushing it in the seal may have gone and causes it to pop out when you hit bumps ect.. i cant clearly say/ explain it but you might have a hunch of what im talking about -- when i go 35 mph some times itll bog/ cant even hear the motor accelerate and i have to pull over and pop w/e back in lol .. end of me guessin
Old 06-16-2007, 05:00 PM
comp comp is offline
any updates ?
Old 02-07-2008, 09:50 AM
Slates Slates is offline
hey check the spark plugs make sure that they are connected to the right spark plugs. because that will cause it to bog down and sometimes backfire through the exhaust. so just check that and also check the carborator make sure that its not flooding itself
CHEVY BOI
Old 03-22-2008, 01:29 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
accelerator pump
timing
check both
if the carb doesnt squirt a nice jet of fuel when you open the throttle then the accel pump needs replaced
then it will not bog when you accelerate
happens commonly
im always having to replace them
i jut had to on an old 4MV Q jet i have on the 82 trans am, the other day
it quit squirting
now of course if the float level is too low then the pump cant pump any fuel
so make sure the fuel level in the bowl is up where it is supposed to be
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
