Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 05-28-2007, 08:42 PM
specialist specialist is offline
transmission problem bmw serie 7
Hi friends, i have a problem with a bmw 1996 7 serie transmission.When i strart driving the car all gears shift fine,but when i come to a stop it won't downshift to first gear,i have to put the car in park and then in drive again and it run ok untill i come to a stop again.any help will be app.
thanks,
Old 06-15-2007, 03:36 PM
Joeboss67 Joeboss67 is offline
Re: transmission problem bmw serie 7
Did you get the problem fixed im having similar problems with mine
Old 06-16-2007, 03:57 PM
No,i'm still sitting with the same problems,although for two days it's shifting up and down very good.
If i got something iwil let you know.
thanks,
Old 06-01-2010, 04:43 PM
jwill01 jwill01 is offline
I have no problem with the performance of ny trans. but I hear a whinning noise and can not figure out where it is coming from. help me!
Old 06-13-2010, 02:17 PM
GOLtech GOLtech is offline
>specialist< jus from wat u mentioned it sounds like a tranny fluid pressure problem. could be a stuck check ball in the valve body. will it shift through the gears in manual
