Old 05-28-2007, 10:22 AM
OJ_ OJ_ is offline
Replacing crossover pipe
Greetings,
I did some searches on this topic but could not find anything. I bought the ZZP ceramic coated crossover pipe and wish to install it. I have been looking around to see if replacement gaskets are necessary but no one can tell me, not even the local auto parts stores.
Are there gaskets I need to worry about when replacing the crossover pipe? Is there any special way to install it or is it as simple as removing 4 bolts and swapping the pipe?
Thanks
2001 Silver GTP Coupe
Self-Tuned - HP Tuner, 1.9s, 105s, Coated Pacesetters(no cat), Poly MM, EGR del, ZZP 1.0 PCM, ZZP MPS 3.25-3.4, AL 104s, Wizair, TBS, 180 tstat, Falken 512s
Old 05-28-2007, 11:54 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Replacing crossover pipe
I never swapped one but you may have to loosen the front manifold to get it out or back in. Then tighten the front manifold. You shouldn't need anything else to do the job although it is quite a job to get the pipe in or out of the area due to lack of space.
