Old 05-28-2007, 02:05 AM
sarotara sarotara is offline
91 PA Ultra Rack and Pinion Replacement
The rack and pinion is going bad in the car. I was curious as to whether anyone here had experience replacing it. The Buick service manual says to lift the car using a suspension hoist and lower the frame by 3 inches in order to remove the rack and pinion. Is it possible to perform the rack and pinion replacement without doing this? Any help would be appreciated. Thanks!
Old 05-28-2007, 09:14 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 PA Ultra Rack and Pinion Replacement
What are the symptoms that make you believe the rack is going bad?
Old 05-28-2007, 11:50 PM
There is a groaning/popping noise when turning the wheel. The noise is a lot more evident inside the car than outside. Raising the front of the car on jacks and placing a hand on the outer tie rods while having someone else wiggle the steering wheel back and forth produces a "popping" vibration in the tie rods.
I'm assuming the rack and pinion is going bad, although I could be wrong. The question is, if this is a rack and pinion problem, whether it's possible to do the replacement in my garage without the use of a suspension hoist.
