Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-28-2007, 01:07 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
16G MBC Tap?
ok so i noticed that the E316g doesnt have a positive pressure nipple on it like the T25 does, anyone have any ideas on how to hook up my Boost controller? i know i could Tee it off the BOV line, but i do not want to have laggy responce. i remeber reading something about tapping the j-pipe with a nipple from home depo? does anyone have any info on that? a pic would help aswell, i have tomorrow (monday, May 29th) off, so i'm going to try and get this all squared away as fast as possible. thanks!
Old 05-28-2007, 12:11 PM
steviek's Avatar
steviek steviek is offline
Re: 16G MBC Tap?
yea you can just poke a hole in the LIcp then screw a tap in that you get from home depot or wherever and then jbweld around the base of tap where it meets the pipe and your all set. (Be careful to not punch a big hole in the pipe make it a small one just large enough to "start" the tap"
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-28-2007, 12:41 PM
Black99GST's Avatar
Re: 16G MBC Tap?
i'm confused as to what to buy at home depo!? do you know what this "tap" looks like? or better yet, what it is actually called? as i said before, Pics of your MBC Positive source would be awesome!
Old 05-28-2007, 05:07 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: 16G MBC Tap?
Yeah man i ran into the same problem. Just go pick up a nipple at the hardware store and jbweld it in. What i did since i still have my t25 is take that nipple off of the compressor housing, the one that u had the mbc hooked too. Drilled a hole in the J-pipe, and threaded it in as much as possible, then JBwelded around it to ensure that it didnt leak. Hope the picture helps.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 05-28-2007, 05:54 PM
Black99GST's Avatar
Re: 16G MBC Tap?
Thanks! and thats just the OEM one off the stock T-25? because i still have my T25 turbo!
Old 05-28-2007, 06:06 PM
Re: 16G MBC Tap?
Yep, took it right off of the old T-25's compressor housing.
94 Talon 1.8L-SOLD
Old 05-29-2007, 07:08 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 16G MBC Tap?
That's what I did, except I didn't even thing to take it off the T-25. I just got one at Home Depot.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-29-2007, 06:46 PM
Black99GST's Avatar
Re: 16G MBC Tap?
i bought one from Home-Depo, and taped into my J-pipe, but the threading is so tight, i had to use a wrench to tighten in the nipple. should i still JB weld it for a seal? are their any "more attractive" ways to insure an air-tight seal?
Old 05-29-2007, 08:56 PM
Re: 16G MBC Tap?
Well in my opinion, if it threaded in pretty tight that should be good enough. I guess if u wanted to be sure nothing leaked u could always throw some teflon tape on the threaded part, cap the nipple, and give it a quick boost leak test. Or maybe throw some epoxy on it which is clear and doesnt give it that "jb weld" look. But i have a feeling if u were to do a boost leak test now without anything on the threads, you wouldnt see any air leaking out. I just jb welded mine because it didnt thread very tightly.
94 Talon 1.8L-SOLD
Old 05-29-2007, 11:10 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 16G MBC Tap?
Some info for the archives perhaps.
All you need is a 1/8th-27 NPT tap, the 21/64ths drill bit that matches it, and a 1/8th NPT to hose barb (of the appropriate size, usually 3/16th or 1/4 for MBC).
Tap the hole so that most of the NPT fitting threads in. Don't tap so deep that the fitting bottoms out before it's tight. Also, don't over-tighten the fitting. Tapered thread fittings use the taper in the thread to seal, if they run out of thread before that happens you have a useless hole.
Teflon tape is good to use, but keep in mind that it's not actually a sealant. It's meant to be a lubricant, so you get the fitting in tight enough to make a seal before friction in the threads prevents you from turning it anymore (leading you to believe it's tight). For a junction that I need to be sure doesn't leak, I break in the threads first (tighten and loosen about 10 cycles, then clean the parts off).
With all of the plumbing we do on turbo cars, it really is a good idea to keep an assortment of pipe thread taps on hand with their respective drill bits. 1/8th is by far the most common. I've used 1/16th for Gus-modding BOVs. 1/4 and 3/8th can be used on larger fittings, like hooking the brake booster up to a SMIM, or making your own ABS intake, etc.
I've recently started converting many fittings over from rubber tubing to hard tubing with instant tube fittings (also known as push to connects). Instant release, no leaks up to very high pressures, and a nice clean install.
www.McMaster.com is by far my favorite source for taps, bits, fittings, just about anything you need for home made parts and projects...
Edit> When I do want an actual sealant on pipe threads, I use the regular Permatex Ultragrey that is used on just about everything else on these cars. This should only be required if you are tapping very thin metal and getting it tight enough might strip it, or in situations where the threads are damaged, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-29-2007, 11:14 PM
AF - Advisor
Re: 16G MBC Tap?
Unrelated to the tapping stuff, I don't think using the BOV line would provide laggy response. Unless you mean slow response of the MBC itself, leading to boost spike. I personally prefer to use the BOV line, or another line off the manifold, since it is manifold pressure that we are actually trying to regulate. I only move it to the compressor cover or LICP if it's a small turbo that gets some boost spike. FWIW.
Kevin Jewer
Old 05-30-2007, 12:04 AM
steviek's Avatar
Re: 16G MBC Tap?
Now all you have to do is define "small turbo" cause I know what kinda monsters you've worked with in the past. (search PSI thread started by me)
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-30-2007, 04:31 PM
Black99GST's Avatar
Re: 16G MBC Tap?
thank keven for that info! however, i already did the tap, and threaded in my nipple, i'm going to go ahead and just use some JB Weld on it however, i'm going to try and tape it off nicely, so it atlease comes out looking like a CLEAN cheap job! thanks everyone!
Old 05-31-2007, 01:05 AM
AF - Advisor
Re: 16G MBC Tap?
Yeah, I think you had mentioned yours was already done. I just can't remember posting about this topic in the past, so the info is now there for anyone else that may search later.
Kevin Jewer
