Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-28-2007, 12:28 AM
deb95603 deb95603 is offline
98 Mailbu noise coming from driver side front tire
When pulling in or out of a parking spot at low speeds, I hear what seems to be a rock or piece of metal inside the tire or at least this is were it sounds to be coming from. I can hear it when I stick my head out the window.
Old 05-28-2007, 07:53 AM
NocturnalCreations's Avatar
NocturnalCreations NocturnalCreations is offline
Re: 98 Mailbu noise coming from driver side front tire
Have u recently had front brake work? Sometimes the metal behind the rotor gets smashed against the rotor and scrapes...wishful thinking because it cost NO money to fix.
Or it could be a wheel hub bearing, but lets shoot for the first suggestion.
97 Seville STS
95 Lumina about to get a 3.8 supercharged
97 Mustang 3.8
06 Charger RT 5.7
Check out the 1 of a kind whips
http://www.cardomain.com/id/NoctrnlCreations
Old 05-28-2007, 10:07 AM
Johnny R Johnny R is offline
If you have the aluminum wheels, pull of the little hub cap to see if a couple of the grip "teeth" have broken off and are ratlling around in there. That was the case on my '99 LS.
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 05-28-2007, 11:35 AM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Also if the alloy rim is it the malibu originals, and does it do it when your slowing down
opcorn:
Old 05-28-2007, 03:46 PM
The noise that I'm hear all most sounds like (when you have a spray can and you shake it to mix it up that's what is sounds like) and it is coming from the front drivers tire.
Old 05-29-2007, 08:09 AM
It must Be the CV Joint then
it does that when it no longer good
opcorn:
