Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-27-2007, 06:43 PM
Mnmracer Mnmracer is offline
Send a message via MSN to Mnmracer
P1294 and starting problems.
In the morninmg when i try to start my car, it will start then die, it is really irritating but i deal with it. I have to give it a little bit of gas to get it going but it picks up its own idle after a while. I had the P1294 Targeted Idle Speed not reached code but i erased it and it hasnt come back in 3 months. I have done many things to fix this problem but nothing, Nothing has done the trick, Ithink my problem is in the air induction to the injectors. Help is greatly appreciated
Old 05-27-2007, 10:19 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: P1294 and starting problems.
Hi and welcome to the forums.
Please use the proper subforums that you can see at the top of the page, a mod will probably move this thread so if you can't find it look in the problem diagnosis area. Also could you please specify what year make and model you are referring to because it will help significantly when trying to diagnose your problem. Thanks and again welcome to AF.
Old 05-27-2007, 11:56 PM
Yeah sorry about that, its a 95 Eclipse RS nonturbo all that jazz. A couple mods which i will list on my profile i guess. AM camshafts, cold air intake, exhaust valve breathers and valve cover breathers
Old 05-28-2007, 07:56 AM
ned032002's Avatar
If you go almost to the top of the screen, you'll see User CP. If you go there you can edit your signature and that is where you should put all your car info so you won't need to keep re-entering it every time you have a problem.
