Old 05-27-2007, 03:33 PM
PamelaNgeorgia's Avatar
PamelaNgeorgia PamelaNgeorgia is offline
NEED HELP,Problems with my transmission
Hello,I have a 1992 pontiac grand prix, I am having problems with my transmission.
It will shift gears just fine while i am driving,But when I have to stop.then there is my problem.It won't go.I have to put it down all the way in first gear and rev my engine up to be able to go.If anyone could please help me,I would really appreciate it.Thank you
Old 05-28-2007, 10:40 AM
thecrow1986 thecrow1986 is offline
Re: NEED HELP,Problems with my transmission
hi can you tell me the millage of your car and engine size , and is it a automatic or standard transmission.
Old 05-28-2007, 11:41 AM
It has 230168 miles and it is a 3.1
Old 05-28-2007, 06:08 PM
Oh sorry it is a automatic.Also it was brought to my attention that It doesn't do it if I have it in drive instead of over drive.But I pretty much have it in over drive,Cause I normally drive 55 to 65.Plus my book that came with the car said to have it in overdrive too.So if u could plz enlighten me and know what it could be,I would really aprreciate it.thank you so much!!
Old 05-29-2007, 08:49 PM
when was the last time the fluid and filter was changed?
I had a beretta with that same engine/transmission and did the same thing
it might need a band ajustment and a new shift sensor. Do you have a transmission specialist nearby with a electronic diagnosis machine?
Old 05-30-2007, 09:49 PM
troy1 troy1 is offline
AF -Advisor
Low sprag is probably out. Another possiblity is the range senor is bad. If you pull it down to "D" from "OD" while driving 55 does the engine RPM increase?
