ABS Mayhem
hmmmm i made the ABS light go away by soldering the broken wires http://www.automotiveforums.com/vbul...d.php?t=557922 however ...... my antilock brake system feels and sounds terrible on the wet roads we have today. seems like just the other side of the firewall (drivers side, engine compartment) there is alot of heavy vibration and noise when i put on the brakes hard (even not so hard), mabey four-six pulses/ second. anyone know the campaign sticker code for ABS reprograming? for now i've pulled the fuse for my ABS..... it is a hazard the way it works now.
any help will be most welcome.
1998 Rodeo 3.2 manual trans 4X4 115,000 miles bought used April 2005 |
Re: ABS Mayhem
You are just fine pulling the ABS fuse. People do it all the time with they offroad with their Isuzus.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Re: ABS Mayhem
thanks for your reply Ryan, I've been driving the Rodeo for years without the ABS (fuse). This ABS light was the last issue to correct, or I thought so......
Can you or someone tell me if the symptoms I described indicate the need for ABS reprograming or another problem?
Re: ABS Mayhem
Isuzu ABS is really noisy when it operates. Mine rarely ever activates, even when offroading on very loose stuff.
The safety campain (02I-002) addressed in service bullitin SB03-09-S001D applies to all '98 and '99 rodeos. If you dont know if yours has been done call an isuzu dealer and the will check the VIN to see if its been done. If not you can take it in to have the controller replaced. Took them about 10-15 minutes to do mine.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
Re: ABS Mayhem
excellent info Dave, thank you very much. I can not belive my ABS is working correctly so i hope the safety campaign applies.
