Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-26-2007, 01:51 PM
gerry97 gerry97 is offline
97 bonny trouble
in the last two weeks i have replaced fuel pump fuel filter egr plus wires ,coils,spark module,tps,pcv,cat. converter and my bonny still has a slight miss and a loss of power .the car works excellent when it is cold but soon as it heats up loses power and stumbles at steady speeds or inclines in the road.when i come to a hill the rpms jump up and down and the car sputters, on pressure test the fuel pressure is between 40 and 48 im running out of money and ideas to fix this problem any helpfull hints would be greatly appreciated thanks.
Old 05-26-2007, 08:00 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 bonny trouble
You need to have this car scanned during this event and utilize the freeze frame function so the operating parameters can be reviewed to help pinpoint the problem, guesswork will not correct this issue.
Old 05-27-2007, 12:07 PM
trigga_b trigga_b is offline
Have you checked for vacuum leaks? spray carb cleaner on the rubber fittings of your vacuum hoses.
