Old 05-26-2007, 12:13 PM
wrench bender wrench bender is offline
abs trouble
abs goes on just before stopping and causes van to pull to the right
Old 05-29-2007, 06:01 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: abs trouble
Welcome to AF
The more inf you give the more we can help.
You need to get ABS codes with a ABS capable scanner to see what is going on.
Post back codes and year and engine
MT
Old 06-01-2007, 08:33 PM
boatbuster boatbuster is offline
Re: abs trouble
I have the same problem on my '02 awd. There is a service bulletin from GM in regards to the sensors not reading the sensing hole in the hub properly. I checked into it and there is a recall where GM will pay for the repair on pick up trucks but they refused to pay for the repairs on my Astro. One person on this forum told me to pull the ABS fuse, but the ABS fuse is the same fuse as the brake lights - so not a good idea. You can google gm service bulletins and it will come up telling you the exact procedure for the repair. GM quoted me almost $1000 to repair mine, so I will do it myself in a couple of weeks. Let me know if you can't find the bulletin and I will dig it out for you.
Old 06-01-2007, 08:39 PM
Re: abs trouble
It's actually called a TBS and this is what it is:
Brakes and Traction Control: All Technical Service Bulletins Brakes - Low Speed (Below 5 MPH) ABS Activation Bulletin No.: 02-05-25-006B Date: January 05, 2006 TECHNICAL Subject: Antilock Brake (ABS) Activation At Low Speeds (Clean Wheel Speed Sensor Mounting Surface) Models: 1999-2000 Cadillac Escalade 1995-1999 Chevrolet Silverado (Old Style) 1995-2000 Chevrolet Suburban, Tahoe (Old Style) 1995-2003 Chevrolet Astro Van, Blazer, S10 1995-1999 GMC Sierra (Old Style) 1995-2000 GMC Yukon, Yukon XL (Old Style) 1995-2001 GMC Envoy, Jimmy 1995-2003 GMC Safari Van, Sonoma 1995-2001 Oldsmobile Bravada Supercede: This bulletin is being revised to update the correction and warranty information. Please discard Corporate Bulletin Number 02-05-25-006A (Section 05 - Brakes). Condition Some customers may comment on ABS activation at low speeds, usually below 8 km/h (5 mph). Upon investigation, the technician will find no
set. Cause The cause of this condition may be an increased air gap between the wheel speed sensor and the hub reluctor ring due to rust and debris built up
sensor mounting surface. Correction Measure AC voltage and clean wheel speed sensor mounting surfaces. 1. Raise the vehicle on a hoist. 2. Disconnect both the front wheel speed sensor harness connectors. 3. Place a DVM across the terminals of each sensor connector. 4. Rotate the wheel with hand speed and measure the ACmV's. The reading should be at least 350 ACmV's. 5. If the reading is between 200 and 350 ACmV's, remove the wheel, caliper and rotor in order to gain access to the speed sensor. 6. Remove the wheel speed sensor and plug the hole to prevent debris from falling into the hub during service. 7. Clean the wheel speed sensor mounting surface using a wire brush, sand paper, emery cloth, ScotchBrite(TM) or other suitable material.
to thoroughly clean the wheel speed sensor surface. There should be no rust or corrosion. 8. Check the sensor head to determine if it has been warped/distorted due to the corrosion build up or other causes. Check the mounting surface
the sensor head for flatness by placing it on the edge of a metal machinists scale or other suitable straight edge to measure the flatness. Check the sensor for flatness in multiple (minimum 3) positions/directions. If the sensor head is distorted, replace the sensor. 9. Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) to the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between coats. Use ONLY Rust Penetrating Lubricant, P/N 89022217 (Canadian P/N 89022218).
10. When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a thin layer of bearing grease to the hub surface and sensor 0-ring prior to sensor installation. Use ONLY Wheel Bearing Lubricant, P/N 01051344 (Canadian P/N 993037). 11. Install either the original sensor or a new one in the hub and secure the sensor. Ensure that the sensor is seated flush against the hub. 12. Install the rotor, the caliper and the wheel. 13. Place the DVM across the sensor terminals and recheck the voltage while rotating the wheel by hand. The voltage should now read at least 350 ACmV's.
Hope that helps you out! Let me know how you make out! With the amount of people I talk to with this problem we should maybe all get together and sue GM for them to repair this issue on our vans!
