Old 05-26-2007, 09:16 AM
radnor radnor is offline
tough one
figure this one out i have a 99 windstar. The problem is i have no power to the guages-windshield wipers - radio, ect when the key is turned on and engin is running i have power to all when key is in acc postion. And yes i have replaced the iqnition switch this problem comes and goes it worked for a month then all of a sudden its back and no power for 2 days now HELP ME PLEASE
Old 05-26-2007, 10:46 AM
wiswind wiswind is offline
Re: tough one
I am wondering about a possible broken wire?
I don't have a wiring diagram for the '99, but would direct you to follow the paths from the ACC and ON positions.....and focus on the parts NOT common to both....but unique to the ON path.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 05-27-2007, 09:47 PM
RickMN RickMN is offline
Re: tough one
In the run position the ign switch provides power to fuses 9,10,28,26. Check for power on those fuses with the ign in run position. If you don't have power, you've got a problem between the ign switch and the fuse box under the dash. In the acc position, ign sw only provides power to only fuse #28. Check for power
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 05-31-2007, 11:40 AM
AvalonJohn AvalonJohn is offline
Re: tough one
radnor,
You in Radnor, PA outside Philly ? That's whereb I'm at ..
AvalonJohn
