Go Back   Automotive Forums Car Chat > Volvo > 240
Old 05-26-2007, 03:24 AM
wuckywuk wuckywuk is offline
Exclamation 87 240 car cranks but will not start. no fire
my 87 240 will crank over but not start. it was working fine until one day i went out and it would not start. there is current going to coil but none going from coil to distributor. i changed coils and coil wire but same problem. the positive side of coil and the ground side both have current when the car is switched on. also the fuel pump is not coming on so i ran a jumper wire on the relay and the pump is working but it still will not start. where coule my fire have gone. please help. thanks
Old 05-28-2007, 05:39 AM
denisond3 denisond3 is offline
Re: 87 240 car cranks but will not start. no fire
I think the fuel pump relay wont continue to work (after the initial period where it runs for one second, and while the starter is cranking) unless it gets a signal that the engine is running. I think it gets that signal from either the distributor, or the injector control circuit.
So I am going to guess: My suspicion would be that either your distributor isnt doing its job (I believe it has a hall effect module inside it) or that the circuit that gets the signal from the hall effect switch and fires the coil isnt working. Its not easy to check for that signal, from ignition module to coil terminal - because with the engine not turning there would be some voltage but not changing, and with the engine turining (being cranked or running) the voltage would be alternating wildly up/down for each plug being fired. Another thing to check would be whether the Volve ignition system has an ignition resistor, and whether it had failed and was 'open'. That is a fairly common failure on the old mopar ignition systems.
Old 01-14-2008, 03:48 PM
jsinton jsinton is offline
I think it's normal behavior for the fuel pump to come on for a second or two then shut off. It's just making pressure in the system. Are you sure you're getting fuel. A really common problem with these cars is the crank sensor. When they fail, it can stop this car. Do search in this forum for VSS, I have another really good post here all about it and how to fix it.
Old 01-14-2008, 03:51 PM
Here, read this...
http://www.automotiveforums.com/vbul...t=speed+sensor
