Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-26-2007, 02:03 AM
rod2004 rod2004 is offline
Rotate tires
Do you rotate tires front to back on the same side or criss cross ?
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 05-26-2007, 09:30 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Rotate tires
I criss-cross the fronts to the back and ten bring the front back.
Every 7k or so.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-26-2007, 10:05 AM
Ramblin Fever Ramblin Fever is offline
Re: Rotate tires
I do mine every 5k - probably depends a lot on the type of tires you're running too.
The Yok's that I have are notorious for wearing badly if they are not rotated every 3-5k; I do my lighter trucks every 5k, and my heavy diesel every 3k with great results.
I criss-cross mine as well.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-26-2007, 01:29 PM
Re: Rotate tires
I have Bridgestone tires
I heard if they are radial tires then you should not criss-cross
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-26-2007, 03:09 PM
Re: Rotate tires
Don't know for sure, I've done it for years without issue.
I do know that if I DON'T criss-cross, they start to wear badly on outside edges on the fronts, on ALL of our vehicles.
Have all my trucks done at Discount Tire
1997 3.2L V6 Rodeo
Old 05-26-2007, 03:18 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Rotate tires
I had directional tires, so I couldn't criss-cross. If I remember correctly, my manual said not to criss-cross.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 05-26-2007, 06:24 PM
Re: Rotate tires
oh I just found out that if you have radial tires then criss-cross is fine.
directional tires need to be on one side only
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-26-2007, 07:41 PM
Re: Rotate tires
I just did a criss-cross since I got Bridgestone radial tires
see what happens
I waited too long to rotate them.
2004 rodeo 3.2L 2WD
AISIN AT
Old 05-27-2007, 11:56 AM
marcre's Avatar
Re: Rotate tires
yea, now that I think about it, there may have been two diagrams in there stating which way to go depending on what type of tire you use.
My Rodeo
Old 05-27-2007, 08:38 PM
Cat Fuzz Cat Fuzz is offline
Re: Rotate tires
If the tires are directional, there will be an indicator on the sidewall. Any other tires you should swap corners to rotate. Can't think of any reason why this wouldn't apply to non-directional tires.
Old 05-28-2007, 04:44 PM
Andie_J Andie_J is offline
Re: Rotate tires
I was informed that with the modern radial tires any type rotation is ok, as long as you dont have truly directional tires. I think the only "front to back, same side" is a hold over form the days when radial tires were first being manufactored here. Before my time lol. Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
