Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-25-2007, 11:31 PM
phantom_bcw84 phantom_bcw84 is offline
Send a message via MSN to phantom_bcw84 Send a message via Yahoo to phantom_bcw84
idle problem
on a 1990 mitsubishi eclipse with a 1.8L. until its at operating temp. it idles low and dies unless your on the gas. and if your trying to drive it barely moves. could this be like a TPS or coolant temp sensor, or is it more like a head gasket thing. once it gets to operating temp. it runs good. kinda lost and need help fast.
Old 05-26-2007, 01:02 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Re: idle problem
does the idle go up once it gets hot?
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 05-26-2007, 01:13 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: idle problem
Check the oil and make sure theres no coolant in it, that should rule out the head gasket. My talon 1.8L did this after i installed an aftermarket intake, and in the process disconnected the wire to the coolant temp sensor. It was trippin a check engine light too, is yours? If so find out what the code means. If not check the coolant temp sensor, because it sounds exactly like what my car was doing. Cutting off at idle until it got to operating temp.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 05-26-2007, 02:50 AM
Re: idle problem
i have no check engine light on. i tried turning the key on and off 3 times to get the codes but it doesn't work :s. is there another way to check the codes? my dad thought it sounded like the coolant temp sensor also. where is it located on the 1.8L? i checked the oil and i dont see any coolant but im going to change the oil and see if any coolant comes out. thanks for the help
Old 05-26-2007, 03:32 AM
smoke121212's Avatar
smoke121212 smoke121212 is offline
Re: idle problem
dude, do you have water coming out of the tailpipe? also, does it over heat?
1996 eclipse gs
cold air intake, thats right im super fast now! wooooooooooooooooooooooooooooooo lol
If a man says something in the woods and there are no women around to hear him, is he still wrong?
Old 05-26-2007, 03:34 AM
Re: idle problem
no it doesn't overheat. stays about in the middle or a little under the middle. the only problem it has is barely runs until its at operating temp
Old 05-26-2007, 03:45 AM
Re: idle problem
then i dont know, sorry dude, hope its nothing too bad for the sake of your wallet lol.
1996 eclipse gs
Old 08-04-2007, 06:47 PM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
Re: idle problem
this is what my car does,revs up by itself like a ghost,then back down and up again,if thats what youre talking about then my street racer friend said its the vacuum system is what has a leak.not getting enough air to operate the turbo and engine itself properly is what that means,i guess.
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
Old 08-05-2007, 02:28 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: idle problem
Sounds resonable. ISC, vacuum leak, any small holes could possibly cause this. Do an air leak check.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 08-07-2007, 10:14 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: idle problem
Answer a few questions for me first. What aftermarket mods do you have done? How long ago did it start doing this? Did you change anything before it started doing this? Is there a strong fuel smell (more than normal) coming from the exhaust or just inside the car when you first start it?
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 08-08-2007, 06:49 AM
inatalonIXLR8 inatalonIXLR8 is offline
Re: idle problem
Maybe take it out somewhere in the middle of the night, somewhere really dark and check to see if there are sparks coming off anything from the coil pack on down to the spark plugs. Try reving the throttle body through different ranges to see if that brings anything out. Just one idea.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
