Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-25-2007, 09:19 PM
CEO Wrench CEO Wrench is offline
95 Monte ABS Light
The ABS light comes on intermittently on my 95 Monte Z-34. I have checked all fuses, replaced the ABS relay, checked fluid level, sprayed brake cleaner on the front wheel sensors, and checked all connections. Any ideas on what else to check before I spend a ton on having the OBD-II diagnostic?
Old 05-26-2007, 07:44 AM
maxwedge maxwedge is offline
A990 racer
Re: 95 Monte ABS Light
It should be scanned for abs codes to stop guess work.
Old 05-27-2007, 07:36 PM
ChevroletTough's Avatar
ChevroletTough ChevroletTough is offline
Send a message via AIM to ChevroletTough
mine did the same thing, it was a wheel speed sensor. check that out, might be bad.
also like max said, check for abs codes, not just general codes if you can.
1995 Monte Carlo Z34 DOHC
1989 Silverado 350cu TBI
Aaron
