Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 05-25-2007, 03:01 PM
niskid240 niskid240 is offline
help!
on a nienty six jetta with the 2.0 in it what is the best way to lift up the clutch lever so that you could put the steel block on the end of the clutch cable.
any help would be greatly appreciated
Old 05-25-2007, 06:55 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: help!
use a prybar on the end and wedge it inbetween the lever part or have someone push the clutch pedal down while you put the clip on
Old 06-28-2007, 11:10 AM
Doug Tatham Doug Tatham is offline
Re: help!
The clutch is self adjusting. If you push the cable all the way in, it will then pull out all the way and you can install the block easily without engaging the clutch.
