Go Back   Automotive Forums Car Chat > Mazda > Millenia/Xedos 9
Old 05-25-2007, 01:15 PM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
2000 Millenia S
My daughters 2000 Millenia with a supercharged 2.3 engine recently overheated. I changed the thermostat and refilled the cooling system and now it won't start. The engine will crank over but won't start. Someone told me to pull the fan relay #2 and use a jumper to get it to start but with the jumper in the car then won't turn off. Does anyony have any ideas? could it possibly be the coolant temp sensor? If so, where is it located?
Links to pics of relay with and without jumper
http://i177.photobucket.com/albums/w...a/HPIM0632.jpg
http://i177.photobucket.com/albums/w...a/HPIM0630.jpg
Thanks for any help,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 05-29-2007, 12:21 AM
rob67gmc's Avatar
Re: 2000 Millenia S
Apparently, very little traffic or very little knowledge in the Mazda section. Think I’ll head back over to the Chevy section.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
