Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-25-2007, 09:54 AM
SuperZu78 SuperZu78 is offline
Fuel Line problem in a 77 Monte Carlo
My car had been stalling and losing power for a few months and, thinking it was a bad fuel pump, I went ahead and replaced it. The new fuel pump didn't help at all and now the car won't even start. I'm pretty certain that the fuel line is clogged, but I'm not sure how I'd go about cleaning it out. Would I need a special attachment for an air compressor, or could I blow the line clear with a hand pump or something along those lines?
Old 05-25-2007, 01:39 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Fuel Line problem in a 77 Monte Carlo
Welcome to AF!
They make a rubber nipple to go on the end of an air blow gun that attaches to your compressor line. I've used that setup in the past to check for a clogged line, or for an obstruction. I've never done a fuel line though. I would have to say though to be safe and not cause damage to disconnect the fuel line from the pump, and the top of the fuel tank. You don't want to blow something into the fuel tank and damage the pickup. You also might want to check the pickup inside the fuel tank. It has a screen on the end and sometimes over the years crud including rust particles can end up blocking the pickup, preventing a good fuel flow to the pump. It's been 30 years and I'm sure over the years debris has found a way into the tank if it's never been apart.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 06-05-2007, 05:59 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
More than likely one of the rubber hose connections on the fuel line is rotted and is either sucking air or has collapsed. Follow it back from the fuel pump to the tank, they tend to rot out high up, so get a flashlight and take your time with it.
Bob
