Replacing Ball joints
Have a 98 2WD and need to replace the upper and lower ball joints. What is the best way to get the rivets out of the uppers? Will an air chisel do the job, or do they need to be drilled out? Thanks.
Re: Replacing Ball joints
An air chisel will work just fine, take your time and go slow.
2006 VW Jetta TDI Diesel (Super fuel mileage) 2004 Chevy 2500 6.0 Crew Cab 1993 Chevy K1500 5.7 (love this truck) |
Will do. Thanks.
When I replaced the ball joints on my '69 Firebird I drilled out the tops of the rivets and then used a BFH and a chisel and knocked them right out. That's actually the easy part of the job.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
