Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-24-2007, 11:23 PM
sydbar81 sydbar81 is offline
Send a message via AIM to sydbar81
valve timing on a 95 3.2
well, my tbelt went, and the cams are completely out of whack. its all lined up and won't start, bad compression, so i have a feeling that this is gonna be a pita.
just wondering if you guys could give me a run through on how to get the cams set properly, i've got the valve covers off, so i'm ready to go.
any help= much appreciated.
Old 05-25-2007, 08:31 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: valve timing on a 95 3.2
how many miles did you have on the belt?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-25-2007, 05:19 PM
maybe 10,000, when i pulled it back apart, the tensioner was toast and one of the idler pulleys would hardly spin, don't buy cheap ebay stuff.
Old 05-26-2007, 10:45 AM
surferfletch surferfletch is offline
There was only 10K on the tensioner and pulley?
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 05-26-2007, 11:04 AM
Isuzu Guy
http://forum.australia4wd.com/index.php?showtopic=7463
there maybe a couple of PDF files that may help you in the above link.
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-26-2007, 06:12 PM
yeah,i got that, i just need to know how to set the cams, they were spun adjacent of each other.
i know its totally wrong, its blowin little fireballs out of the throttle body.
am i basically just goin for closed at tdc on all cylinders, or is there more to it than that?
btw, the idler failing is what caused it,reused it cause it seemed ok. the belt and tensioner had 10k, but the tensioner was already leaking fluid.
