Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-24-2007, 10:45 PM
luvcrika luvcrika is offline
problems with after market rims
i'm having a problem putting on 20's on my lincoln ls 2001 please help, what do i need it hits the brakes on the front and i brought 5/16in. spacers but now the hub adapter doesn't reach.
Old 05-29-2007, 07:59 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: problems with after market rims
you simply have the wrong offset.
The LS uses a 60mm offset stock - meaning that the mating surface of the hub and wheel are 60mm of-center toward the front of the rim.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
there is very little you can do except get wheel with the correct offset.
With the spacers - you have already moved the weight of the wheel farther out on the suspension - which with the additional weight of the 20" is not a good idea.
Going with longer studs will make the rim lug centric instead of hub centric like the stock rims are.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
