Old 10-24-2002, 07:37 AM
toyosupr toyosupr is offline
b16a supercharger(compression?)
i have a b16a stock compression is 10.2 what compression should i use with the jr supercharger. i also have 55 zex, skunk2 head, and all the other stuff you could put on the engine if that matters. i want to upgrade the pistons and rods for future abuse and hp so what compression should i choose......
Old 10-24-2002, 08:02 AM
Fireinthesky28's Avatar
Fireinthesky28 Fireinthesky28 is offline
Send a message via AIM to Fireinthesky28
Re: b16a supercharger(compression?)
:huh:
So the biblical scholars mis-translated the Hebrew word for "young woman" into the Greek word for "virgin," which was a pretty easy mistake to make, since there is only a subtle difference in the spelling. But back then it was the "virgin" that caught people's attention. It's not every day a virgin conceives and bears a son. So you keep that for a couple of hundred years, and the nexy thing you know, you have the Roman Catholic church.
-Snatch
Old 10-24-2002, 04:25 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you can run the stock comp ratio of 10.2 with the jrsc. make sure you dont run a dry nos with your jrsc. you need wet nos. you can run the stock comp ratio with all the other parts too
Old 10-24-2002, 06:33 PM
why no dry jr said it was fine as long as i put the line in after the air was compressed (tap the plenum chamber of the manifold, directly across from the intake ports)
Old 10-25-2002, 12:36 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
run what ya got it should run fine and the stock compression ratio should work fine if it didnt im sure jackson would try to sell you some lower compression pistons or something money grubbing sob lol sorry
Old 10-25-2002, 12:41 AM
if you tap into the intake mani then your looking at a fogger system
Old 11-09-2002, 09:27 AM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
i was about to buy a dry nos system, i didn't know that it wouldnt be smart with my supercharger, can someone tell me why and what i can do about it?
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
Old 11-09-2002, 01:24 PM
well toyosupr said that jackson racing said he could run nos as long as its a fogger system or direct port. after the air is compressed
so if you wanna run nos on your car with a jrsc, run either a fogger system or direct port.
to be safer why dont you call jackson racing and ask them, also call teh nos company and ask them too.
Old 11-09-2002, 03:56 PM
how does the fogger system hookup compare to the dry...
Old 11-09-2002, 04:27 PM
In a wet system, nitrous oxide and fuel mixed are at and then delivered through a "fogger" which is directly threaded into the throttle body (or intake tube). Steel braided lines are attached to the N2O bottle and the fuel system and are opened and closed via switching solenoids.
Inside of the nozzle are "jets" which determine the amount of N2O sprayed into the engine. This is what actually determines the amount of "shot" that any given kit will produce. The larger the jet, the higher the horsepower output and vice versa.
The dry manifold system is similar to the wet system, however the fuel and nitrous oxide are NOT mixed at the fogger. The N2O is injected into dry air (without fuel) upstream in the manifold and it is then mixed with fuel at the injectors. Since this type of system has no real means of adding the additional fuel that is required to burn the extra oxygen, it should only be used for less than 70 hp shots with factory injectors.
Direct-port systems are by far the best for reliability and power, but are also the most expensive and most difficult to install. This kit is basically a "wet kit", but each cylinder getting its own fuel/nitrous nozzle. The fogger injects the nitrous and fuel directly into that cylinder's intake port. The installation of this type of kit requires that the intake manifold be removed from the engine. These kits offer the highest horsepower shots due to their ideal N2O/fuel mixture at each cylinder. This would be the "must have" kit for the serious strip racer.
so a fogger is nos mixed with fuel, dry is just nos, direct port is nos mixed with fuel but each cylinder gets its own nozzle.
Old 11-09-2002, 04:56 PM
from what i understand about the jrsc. right after the blower unit itself, it divides into each intake runner for each cylinder. so the only option i see when running nos with a jrsc is to tap into each of the 4 intake runners and run nos in each of the intakes, which would then make it a direct port. because after the blower unit, its compressed air, and not before it. so only after the blower unit its compressed air and it goes right into each intake runner, so the only option i see is to tap into each intake runner which would make it direct port.
sorry i did say fogger before but after thinking about it, i was wrong, you should use a direct port with any type of forced induction
i strongly recommend you call the nos company and ask them about what type of nos systme you should run with a jrsc. they will give you the absolutly correct answer.
b16a lsd vs b16a non lsd 91blublaze Engineering/ Technical 16 10-14-2003 03:20 PM
JDM OBD-1 B16a head for sale, OBD-1 B16a engine harness for sale, GSR intake manifold CRXtc Engineering/ Technical 0 09-09-2003 10:23 AM
Turbo B16a VS Stroked B16a EF9JDM '88 - '91 Civic | CRX | Wagon | Shuttlee 28 09-03-2002 06:15 PM
b16a sir 1 vs. b16a sir 2 Mastashock13 Engineering/ Technical 7 01-16-2002 02:06 PM
