Old 05-24-2007, 06:19 PM
nukeman nukeman is offline
Swapping mirrors
Just purchased a 2002 2500 HD that has had the OEM mirrors removed, and non-power mirrors installed, (it originally had power mirrors). My question is, I have an '03 Silverado with the Power/Folding/Heat/puddle/dimming/signal mirrors on it and I want to swap them to the 2002. I don't really care if the signals etc. don't work, I just want to power adjust them I removed the mirrors and obviously the harness is different, but will they work if I just swap switches? THANKS!
Old 05-24-2007, 07:11 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Swapping mirrors
Unless the moron that owned the truck before you cut the harness, it should still be there when you remove the mirrors.
Should be a simple plug and go operation.
I hope it is for your sake.
*Under Construction - New sig to debut*
Old 05-24-2007, 07:27 PM
The harnesses are intact, BUT they are completely different. '02 harness has a 5 pin plug, '03 mirror has 2 separate harnesses with a total of 15 wires. I'm looking into whether I can swap out window/lock switches and take care of it (bcause the mirrors plug into the window/lock switch). Who knows.
