Old 05-24-2007, 07:48 AM
bochnak bochnak is offline
92 Accord - Fuel pump or distributor?
My car died during cruise. I pulled over and it cranked more than usual, but fired right up.
Has newer main fuel relay and fuel filter. Ignition sytem (plugs, cap, rotor) are in good shape.
I wondering if I have a problem with my fuel pump or distributor going bad.
Where is the fuel pump located? Under the rear seat? Also, if the distributor is going bad, would it be problematic intermitently or go for good?
I want to get ready to diagnose this problem next time it happens. I will have tools to check for spark and have access to the fuel pump.
Thanks,
Matt
Old 05-24-2007, 02:52 PM
n8zdogg n8zdogg is offline
Re: 92 Accord - Fuel pump or distributor?
During what?
Old 05-24-2007, 03:15 PM
Originally Posted by n8zdogg
During what?
During cruise.
Old 05-24-2007, 08:46 PM
mpumas mpumas is offline
Fuel pump is in the gas tank. First possible is ignition coil, followed by igniter. Then fuel pump. You need to get in a no start mode, then check for spark. You can check for fuel pump operation with a pressure guage on the fuel line/manifold. I 'll bet on an ignition coil problem.
Old 05-25-2007, 07:05 AM
The igniter was the culprit. It died on me several times on the way home from work. Luckily, the symptoms occurred in my driveway and was able to test for spark. I found no spark from the coil terminal. Tested coil and it was good.
I guess the igniter tells the coil when to spark. My buddy owns a shop and he had a used OEM igniter that he gave me. Runs great now.
BTW, the distributor looks newer and non-OEM. The shaft was tight with no play.
-Matt
Old 05-28-2007, 10:31 AM
lude speed lude speed is offline
Be careful with that. I haven't had any luck with any distributors other than OEM. Glad you got the problem solved though.
My Car Domain
Old 05-29-2007, 06:47 AM
That's what I hear. I'll replace it later. I have motor mounts that need some attention.
