Old 05-23-2007, 05:04 PM
Cobra04 Cobra04 is offline
Water leak/Paint Code
#1 Vehicle is a 96 PA Ultra with a water leak somewhere in the trunk. It appears to be wet directly under the deck lid latch assy.. Has anyone else had this leak in the same area and if so did you happen to find where it was coming from.
#2 Where can I find the pain code for this same vehicle ? I found a tag in truck with QUITE A BIT of numbers on the tag but I have NO idea if this is it or even which one is the paint code.....vehicle is two tone as well
thanks
Old 05-23-2007, 07:23 PM
northstar1958 northstar1958 is offline
Re: Water leak/Paint Code
Cobra;
No such water leak on my 97, but this might get you started in understanding your paint code. Good luck
Northstar
http://www.sherwin-automotive.com/he...on_2001.cfm#gm
Old 05-24-2007, 12:40 AM
bigsky bigsky is offline
Cobra...check out the thread on "RPO Codes" in the Buick "Tips and Maintenance" section to get started. Discovering the RPO codes and researching them is great fun if you are "into" that sort of thing.
I believe the color codes are on the bottom of the tag. You will see things like "CC" (clearcoat), "BC" (basecoat), decal options and other codes to help understand your vehicle.
Old 05-25-2007, 05:12 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
It sounds like you found it, but just in case, your RPO codes are on a 3x4'' label on the spare tire cover. Check your weatherstripping near that latch, see if it is seated properly, or possibly damaged?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
