Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 05-23-2007, 02:07 PM
aj98 aj98 is offline
A/C bypass
The other day the A/C compressor on my 98 zx2 seized and calling around it will cost far more than I am willing to pay to fix the POS as i never use A/C so before i start trying this. Is it possible to route a smaller belt and bypass the A/C system completely?
Old 05-23-2007, 11:32 PM
Markb873 Markb873 is offline
Re: A/C bypass
ZXTuner.com sells a pulley to go in place of the compressor. It's $90, you can probably find one cheaper if you shop around.
-Mark
Old 05-31-2007, 07:43 AM
reekor reekor is offline
Talking Re: A/C bypass
I would unplug the power plug from the A/C clutch and save the $90
-Mark
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-06-2007, 08:54 PM
Re: A/C bypass
thanks for the help but just ran a shorter belt after a short time figuring out the new routing. As far as just unplugging it that would work if the internal bearings hadn't exploded.
cost $28.36 for a new 69.5 inch belt
Old 07-07-2007, 06:22 AM
Midwestzx2 Midwestzx2 is offline
Re: A/C bypass
I did the same thing, im runnin a 70 inch belt and that is a tight fit, 69.5 must be reallllly tight.
