Old 05-23-2007, 11:44 AM
Big Dan58 Big Dan58 is offline
Send a message via Yahoo to Big Dan58
2000 WIndstar armrest
Hello All,
Thanks for trying to help!
I have a 2000 Windstar that I can’t take off the arm rest. Is there a special tool or is there a special way to remove it?
Thanks!
Big Dan58
Panic, Chaos and Confusion... My work here is done!
Old 05-23-2007, 09:43 PM
catvents catvents is offline
Re: 2000 WIndstar armrest
Originally Posted by Big Dan58
Hello All,
Thanks!
ON the side of the armrest you have a plastic cap that you have to remove.
Take care for no breaking it. Under that cap, you have a kind of steel washer with a hole in it. Take a long nose pliers and slip the steel washer out of the arm rest. Then you will see a torx bolt T40 or T50 that you will unscrew and make your armrest removed from the seat.
Old 05-24-2007, 06:57 PM
The armrest on this one has no plastic cap on the side. It is completely covered.
Big Dan58
Old 05-24-2007, 08:58 PM
Yes I'm wrong, I think this apply for a 1999 model.
OK raise the armrest to the upright position. Going by the front of the seat,
push the leather or material ( where the mechanism is) and you will see a little white clip with a tab; with a small screwdriver remove this clip and after, just slip the armrest from the mecanism. To re-install, install the clip, and slip the armrest in his regular position.
