Old 05-23-2007, 12:17 PM
bowser14 bowser14 is offline
turbo 350 no foward gear
79 chevy 1/2 ton. tranny just quit going into any foward gear. reverse still working fine. any ideas?
Old 05-23-2007, 03:06 PM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
Re: turbo 350 no foward gear
shift cable came loose?
check your fluid levels and all.
really i'm just guessing.
when did this happen? what were the circumstances between when it worked and when it didn't?
that information will help a bit.
all your are belong to us.
Old 05-26-2007, 02:23 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Let me see here, it works fine in reverse but all forward motion is gone. You can rule out a torque converter or front pump issue. A front pump issue will show its teeth in reverse before any other gear.
Check the fluid. If it's brown, black, murky, looks like metallic paint or smells strong (even if it's red or orange-red), or any combination of the above, my first guess would be forward clutch. This is the typical TH350 failure where it works in reverse but not forward. The forward clutch engages in all 3 forward gears (hence forward clutch).
I don't know how else to describe it, but good fluid will be orange-red to bright red in color, clear and with a sweet crayon smell.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
