Old 05-23-2007, 06:29 AM
goer42 goer42 is offline
removing engine from 96 g-am
I am in the process of pulling my engine. I have done rear wheel drives but not fwd's. is it easier to pull engine&trans? do you drop the frame? I am afraid i dont have enough room to slide the engine forward without hitting the inner fenderwell. I was thinking maybee i need to take that tranny mount off so i can slide tranny back a bit? HOW DO YOU GET TO THAT BACK TRANNY BOLT? heck i have tried every position possible , i have even stood on my head. I dropped the exausht down and i think that made it worse. please give me some insight. thanks
Old 05-23-2007, 10:10 AM
justin0717 justin0717 is offline
Re: removing engine from 96 g-am
Well when i did my 96 with a 2.4 i pulled the motor/tranny out together. Then disasembled out of vehicle. It took some manuvering, but they both came out the top w/ no prob. But i pulled both out together b/c i was replacing both motor and tranny.
In order to get the back bolt on the tranny you need a long entension (2-3 ft)and a swivle 15m. Go in through the RF wheel well, you may need to remove the bracket that goes from the block to the tranny (need to remove anyways if pulling motor) you should be able to get the bolt that way. Any other questions let me know, i did it a few years ago, but ill help if i can...
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 05-23-2007, 07:26 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
What engine ?
1999 Grand Am SS 3.4 OHV
Old 05-23-2007, 11:28 PM
sorry about thAT. IT HAS THE 3100. i tryed taking one out the bottom out of the donor car and that wasnt alot of fun. should i pull the engine and trans as one and then put them back in as one or is that not nessecary?
Old 05-23-2007, 11:30 PM
I did also take off the master cyl to make some more room.
Old 05-24-2007, 10:13 AM
The engine will come out from the top but the engine to trans mounts need removed. The mount bolts for these are in tight spots, which usually means wrenching as opposed to ratchet.
And you can drop the trans and not the motor .
Unless you need to work on the trans I see no real reason to remove it, just more work.
Old 05-24-2007, 07:06 PM
thanks alot. I will give it a try. you must be talking about the brkt. on the right hand (passenger side) of the car. Thanks again
Old 05-24-2007, 07:17 PM
Yes.
OH yea, you would also want to remove the exhaust manifolds bolts.
The exhaust can just stay in the car.
