94 Ranger Intermittent No Start
I have a real head banging problem with my 4.0 L '94 Ranger (5 speed manual). Intermittentantly it wont start after I drive it and park it. Just a click and the starter motor whirring when turning the key. Like it is not getting any gas, it just wont turn over. If I let it sit for a few hours it starts just fine. I replaced the fuel pump, and fuel filter but that did not solve the problem. (Battery and clutch is new too but problem still persists). Would an OBD 1 or 2 Analyzer work for me? Any ideas to what might be the problem? Ate wits end .. Mark
Re: 94 Ranger Intermittent No Start
check to see if the electrical connections at the fuse box under the hood is good.
starting to love my 93 ranger w/3.0 5 speed. |
Sounds like your starter solenoid not working inermittently. The whirring sound you hear is the starter turning with no load because the solenoid gear was not engaged. Remove your starter and have it checked out. If the solenoid is bad, might as well get a new starter. They are not that expensive. I don't believe there is an OMB indication for starter solenoid problem
If the engine turns over and doesn't start, check your fuel pump relay and the relay adjacent to it in the fuse block. I believe it is called EEG Power relay. The power to the fuel pump must go through both these relays.
G Dan |
Thanks for the reply. I am sorry when I said the starter motor whirrs. I should have said the starter forces the the engine to turn over but there appears to be no combustion.
GCDAN, I think you may be onto the answer here. I'll test the fuel pump relay and the EEG power relay this weekend.
e_powers, thanks for the that idea too. I'll check it all this weekend.
