Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-23-2007, 03:01 AM
dsun87 dsun87 is offline
Question wastegate and boost control
i was wondeirng how do i set a wastegate setting lower?
is it just a change of spring?
also can a manual boost control actualy control the boost i want?
and is there a way of manual controling the wastegate?
Old 05-23-2007, 03:30 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: wastegate and boost control
There are different springs you can get for the external wastegates if you want to run lower boost than the boost controller will actually go... Although I'm not sure where you actually buy them at. I think you have to get them from the maker of whatever brand wastegate you have...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 05-28-2007, 02:03 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
1) wastegate can be set for lower pressure with a lighter $20.00 spring, or an added spring in the other direction (home depo mod= $0.75)
2) Manual Boost Controller (MBC) CAN actually control the boost you want, its wonderful!
3)the way of manual control for the wastegate would be the same thing as controlling your boost levels, which ironically is done the same way, With a MBC!
hope that hepls!
Old 05-29-2007, 11:58 PM
kjewer1 kjewer1 is offline
AF - Advisor
Two points worth mentioning are that the MBC can never set boost lower than the WG spring pressure, and using a spring that is less than half the boost you intend to run can cause erratic boost problems (at least at higher pressures, like 25 psi up).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-30-2007, 12:04 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
This I'm guessing happens all the time, but is only more prominent at the higher boost. Almost all the manufacturers I've seen that make WGs (except for eBay brands) had other springs that you can buy that offer lower adjustments. They are cheap, and it's just easier to go straight through the manufacturer. I would also only trust going that route because these springs are made specifically for the WGs and that specific boost. Seems just like the best way to go.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-30-2007, 03:45 AM
AF - Advisor
I think it was RRE that had a really nice Tial WG spring combination chart, if anyone is looking for that info.
Kevin Jewer
