Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-22-2007, 10:27 PM
metalphreak529 metalphreak529 is offline
Hard shifting transmission
My 97 crown vic interceptor has a real hard shift it has a possible 140k on the tranny and 90k on the engine. Should I change my fluid or leave it alone? any suggestion are appreciated.
Thanks
Old 05-22-2007, 10:52 PM
Re: Hard shifting transmission
I forgot to add something before... The gears are not slipping at all it is just shifting very hard. I am just not sure if it would be smart to change the tranny fluid. especially if im not sure if its been changed ever.
Old 05-23-2007, 09:10 PM
1996Chreokee 1996Chreokee is offline
Is the fliud bright red? or is it burnt and brown?
Depending on your plans with the car... If its a driver and its burnt I would leave it alone and let it run its course.... but If its something your going to keep and don t mind putting a tranny in it preventive maintenance is always good...
Is it possible theres a shift kit in the tranny? or did it one day start shifting hard?
good luck
Old 05-24-2007, 08:07 PM
THe last owner actually told me it had always shifted hard. But I dont think there is a shift kit in it it really doesnt feel like it. But it is something I will have till it dies so im just tryin to figure out how to make it purr you know. So I should change it? its not slipping at all
Old 05-24-2007, 08:10 PM
if the fluid is nice and clean i would leave it alone.... actually i would leave it alone anyways... It may run a long time with that condition... those car you can pick up a new tranny on ebay cheap if it goes bad
goood luck
Old 05-24-2007, 09:31 PM
reekor reekor is offline
Have your car scanned for shift solenoid issues. Wrong transmission fluid could also give you hard shifts. So the answer would be yes....
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 05-28-2007, 06:23 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check the 1-2 shift accumulator spring. They are bad about breaking and will give a really hard shift.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-03-2007, 12:10 PM
Thanks everyone for your help... wish me luck
Old 06-03-2007, 06:52 PM
way2old's Avatar
TOKEN HILLBILLY
Good luck.
